stalling problem
Old Sep 19, 2005 | 11:37 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
stalling problem
For tha last month or so my 86 has been stalling, usually once or twice in a short trip. this morning it stalled and would not start again, checked with a test light, getting no pulse at injector harness. two minutes later car starts runs a few minutes and stalls. Then the fuel pump relay turned on and off 4 or 5 times, swapped in another one, did same thing.
This all happend three or four times, start, stall, no pulse, funny f/p relay.
Car did the same thing with 2 different coils and 2 different ignition modules, the ohms across the p/u coil is within spec.
I leaning towards the ecm.
Any other opinions out there?
Thanks, John
Old Sep 19, 2005 | 10:08 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I can tell you that my car did something very similar. I would drive it for a good amount of time and heat it up and then shut it off. If i would go and start it again all hell would break loose. It would die without warning just driving down the road. So my shop told me that the ECM was probably bad cause it was throwing codes like crazy. I replaced it and the PROM and it shifted better and idled better but still would die in the same way. So back to the shop it went. They thought it was the distributor messing up so they put a new one in and then kept it for a few days and test drove it. It continued to do it for them until they replaced the MAF sensor. Then it never died on me again. I guess through all that it could be your ECM or it could be your MAF sensor. Hope that helped somewhat.
Old Sep 20, 2005 | 05:30 PM
Thanks, that did help, I put a new MAF in it today it seems to have straightened it out.
Old Sep 20, 2005 | 05:39 PM
subroc's Avatar
Engine: 355 TPI
Fantastic...glad i could help. I wish i knew about this board when my car was acting up so maybe i could have saved all that money. Good luck with your car!
Old Sep 21, 2005 | 06:32 PM
Car stalled again today, so I dug a little deeper, found that the f/p relay and the maf power relay were swapped around.
I've read here that some folks say they are interchangable, after what I've been through the last week or so, I would tend to disagree (No offense meant). I'll see what happens the next couple of days.
John
Old Sep 21, 2005 | 06:57 PM
subroc's Avatar
Engine: 355 TPI
Well good luck...i hope swapping those wired back helps. If it doesn't then i would bring it to a shop and have them put a scanner on the computer. It shouldn't cost to much..just make sure to tell them not to do the work on it if they find out whats wrong. Shops are too damn expensive!!
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
