TPI Motor Not Starting After Paint Job
Old Sep 25, 2005 | 11:38 AM
musict's Avatar
91 TA (Stock) TPI 305. I am completely lost!!!! Car was on jackstands for 2 months and it ran fine before this. Started car and it idled ok. When I pressed on the accelerator the engine died. I depressed shrader valve on fuel rail on no pressure. I replace fuel pump and filter...... still nothing.
Is ther something I did during the painting process to cause this??
Please help!!
Old Sep 25, 2005 | 02:33 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
can you hear the fuuel pump coming back on when you put the key in the ignition?
Old Sep 25, 2005 | 03:14 PM
musict's Avatar
The fuel pump is not running when the key is turned on.
Thanks!!
Old Sep 25, 2005 | 07:08 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Check the fuse in the fuse holder up by the passanger side fender area. See if it blew.
Old Sep 25, 2005 | 10:09 PM
IraSummers's Avatar
Car: 2005 colorado 2wd, 1986 fiero GT, 1989 Firebird
Engine: None yet
Transmission: auto
also check your relays and wiring...
Old Sep 25, 2005 | 10:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did you change the original color? If so, you need to reprogram the prom.
Check the DIY_PROM forum for futher advice.
Frozer!!!
Jan 19, 2024 04:55 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
kyle5647
Aug 7, 2015 03:08 PM
L98GTA87
Aug 5, 2015 11:02 PM
