Need help
Old Sep 27, 2005 | 11:02 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Need help
Today, my 1991 Camaro Z28, 5.0L V8 spit out four codes.
33
42
43
54
CAn someone help me out what some of these codes mean?
Old Sep 28, 2005 | 10:24 AM
Hoop88Z's Avatar
Car: 1988 IROC -Z28
Engine: 5.7L TPI
Axle/Gears: 2.77
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
43. Low voltage at electronic spark timing circuit
54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
Good luck!
