hey guys i got a 1987, im an automotive student and wanna juice it up before it goes on the road
350ci tpi with a t 5 conversion
stock and idles like **** when cold probly iac * hehe ill buy one of those later haha*
id like to get an emmisions legal combo,
for about 2k, intake and minor heads i want about 320- 350 hp or so
i believe the stock is rated at 215 330 ft pnds so, i dont think it would take much, maybe a cold air, edlebrock base slp runners and ported the hell out of the plenum/runners like in that other post with those insanely ported slpr's hehe
get back to me THANKS
n20, you have the power when you want it and can still pass smog (if car could pass smog test stock)
87TPI350KID
close
- Join DateAug 2004
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1987 IROC-Z Camaro
- Engine5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
- Transmission700R4 - Shift Kit, Corvette Servo
- Axle/GearsBW 9 bolt, 3.27s
- Liked:0 Times in 0 Posts
Vortec heads, votec tpi base, slp runners ported to match your plenum, some 1.6 RR to help the lift on the cam, and headers and exhaust should be good for about 270 hp. If you got a different cam 320 wouldnt be impossible.
dude i saw 1300 vortech heads that add +80 hp ....HOLY CRAP ROFL
yeah thats what i was thinking those heads edlbrock base and slp runners ported to hell rofl, and a 58mm bbk up front and cold air
im not to good with cams hehe
87TPI350KID
close
- Join DateAug 2004
Heads - Check
Vortec* Base - Check
Ported SLP Runners - Check
Ported Plenum - Check
58mm TB - No
SLP Headers - Check
Decent Catback - Check
These alone are worth 280 at the wheels. Or if you don't feel going the vortec route, a stall converter around 2800 would compensate off the line.
why not a 58mm, that way even if it was overkill then it would let ,me have more flex for hp because thats the best flow i can get right there
thou i have heasrd the 52mm is more then enough
58MM isnt needed until like some crazy HP like 450-500. And by then....lets just say stock is fine.
If you let in too much air, only for it to find a restriction further down the line, turbulence is created and velocity takes a dump.Originally posted by fire350tpi
alrighty so the 52mm would work fine then
