fuel pressure!!
Old Oct 5, 2005 | 04:31 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
fuel pressure!!
what is the stock fuel psi on the l98 tpi? what do u guys recommend on a semi built engine as usual headers, mild cam, 24 lbs injectors, granetelli fuel pump, better air induction system, bbk 52 mm, and jet chip. i have a adjustable bbk fuel pressure regulator layign around what do u guys suggest?
Old Oct 5, 2005 | 04:50 PM
ibwsjerry's Avatar
Car: '89 iroc
Transmission: th-350
i got almost the same mods minus the 24lb injectors, i have stock and mine is at 52psi w/ vaccum off. Made a big difference WOT top end, from 4k until redline.
Old Oct 5, 2005 | 05:37 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
how does not runing the vacumm work?
Old Oct 5, 2005 | 07:19 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I think whtt he is saying is he set it at 52 w/ the vacuum line disconnected, then pluged it back in.
Old Oct 5, 2005 | 07:31 PM
ibwsjerry's Avatar
Car: '89 iroc
exactely, set it with off then plug back in.
Old Oct 6, 2005 | 04:37 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
k thanks
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
