What are these lines for?
Old Oct 7, 2005 | 07:27 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Well im doing some cleanup on my engine bay and Im wonder what these lines are for (circled in yellow) they go from the somewhere around the TPI plenum back into the firewall. Is this for the AIR system that goes to the cat? or what
Old Oct 7, 2005 | 07:28 PM
brutalform's Avatar
Fuel supply, and return lines.
Old Oct 7, 2005 | 07:29 PM
JDubya18's Avatar
Engine: 305 LB9
So its probably not a good idea to remove them thanks for the help
Old Oct 7, 2005 | 07:46 PM
brutalform's Avatar
Your welcome. You have a very tidy engine bay there! If you would like to make the lines look nicer, you can add some braided steel lines, in place of the stock ones. I believe Accel sells fittings #74730 just for this purpose....just a suggestion, if you dont like the stock ones.
Old Oct 8, 2005 | 02:38 AM
JDubya18's Avatar
Engine: 305 LB9
Haha I wish mine was that clean. I just used that picture because it showed the lines good and I didnt have one of mine. The stock ones are kinda in the way maybe Ill check out the Accel ones. Thanks again
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
