TPI build suggestions
Old Oct 17, 2005 | 12:49 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
Im wanting to make 300hp, and no power adders or nitrous..
So far i have the following installed:
hedman hedders
3.5" mufflex system (waiting install)
L98 heads pocket ported
Im about to purchase:
Holley Stealth Ram
Holley SR fuel lines
BBK 58mm Throttle body
Cam (NEED SUGGESTIONS)
What do you think???
Old Oct 17, 2005 | 01:08 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
As long as those heads were ported well, and have bigger valves, you should be at 300 hp. Make sure you get it tuned too. Other wise you will be dissappointed. Many go with the LT4 hot cam. That cam is a love hate cam. You either love it or hate it. Othe popular cams are the CC306 (230/236), Or a 224/230 cam.
Old Oct 17, 2005 | 05:50 PM
Fred91GTA's Avatar
Car: 1991 GTA
You might want to go with a 52mm Throttle Body instead. 58mm TBs are made for monster engines. In fact, a 58 could actually hurt power if you don't have a combo that can utilize the extra air flow of the 58.
Orr89RocZ
Apr 25, 2016 08:28 AM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
drathaar907
Aug 6, 2015 04:20 PM
