which trick flow heads for 88 tpi?
Old Oct 22, 2005 | 06:15 PM
TPInside's Avatar
Car: 1990 Formula
Engine: 5.7
which TF heads for 88 tpi?
can anyone recommend some part #'s to check out for trick flow heads?
i want to keep all my emissions and my centerbolt setup.
just want a set of heads that are fully assembled and ready to install except for maybe some 1.6 rr's.
i have a zz4 cam and bolt-ons already.
i found TFS-30400005 & TFS-30400006 at summit.
are those my best bet for $ and compatibility?
Old Oct 22, 2005 | 07:11 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you are going to do future mods I would go with the 304-00007 heads with the dual springs and the safety factor of two springs. Stay away from the 304-00005 heads as they are only good to .525" lift. You will max them out with your ZZ4 and 1.6 roller rockers.
Old Oct 22, 2005 | 07:39 PM
TPInside's Avatar
Car: 1990 Formula
Engine: 5.7
yeah i saw those too.
didn't know if i needed that much.
how did you calculate the lift?
sorry i'm new to this head stuff.
by max out you mean they will only flow so much and not use all air i'm pushing through?
i might look into a turbo or super in the future too so if that's the case, i'll save up a couple hundred more bucks.
Old Oct 22, 2005 | 10:09 PM
Car: 1989 GTA
Engine: 369 TPI
By maxing out you will bind the springs and have a failure. I believe the exhaust lift with 1.5 rockers on a ZZ4 cam is .495 inches. With 1.6 rockers it becomes .528 inches and that is more than the 00005 heads can take without mechanically binding.
Old Oct 22, 2005 | 10:22 PM
TPInside's Avatar
Car: 1990 Formula
Engine: 5.7
you're right, the max lift for the 00005 is .520
the 00006 is .540 and 00007 is .600.
still think i need that much lift or just mainly for the safety if i use power adder later?
Old Oct 23, 2005 | 11:36 AM
Car: 1989 GTA
Engine: 369 TPI
If you are going for more power down the road I would go for the 0007 heads. They will handle about any cam you want to put in your motor.
Old Oct 23, 2005 | 02:54 PM
TPInside's Avatar
Car: 1990 Formula
Engine: 5.7
well i don't plan on upgrading to a bigger cam than the zz4.
which tf's are you running on your gta?
can you keep the stock valve covers?
i want to use 1.6 rr's too and want to make sure they fit, can i use self aligning with these heads
thanks for the help.
marty
Old Oct 23, 2005 | 03:13 PM
Car: 1989 GTA
Engine: 369 TPI
I'm running the 00007 with 1.6 rollers and stock valve covers with a ZZ9 cam. Going to the Comp Cams XFI268HR-13.
Old Oct 23, 2005 | 06:04 PM
TPInside's Avatar
Car: 1990 Formula
Engine: 5.7
very cool.
which rollers (brand/self aligning) and pushrods (brand/size) are you using and did you have to buy or recommend anything else when doing all this at once?
Old Oct 23, 2005 | 07:10 PM
Car: 1989 GTA
Engine: 369 TPI
I'm using the factory pushrods.
Old Oct 23, 2005 | 07:40 PM
TPInside's Avatar
Car: 1990 Formula
Engine: 5.7
really? the summit catalog said special length pushrods required.
what about those rollers, what are you using, steel, alum, self aligning?
sorry about all the questions but you have a similar setup to what i have and i'm looking for.
Old May 19, 2009 | 12:30 PM
89gtajustin's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7 350 L98
Re: which trick flow heads for 88 tpi?
do you knoe wat my 89 gta would put out for rwhp its basically an all stock 5.7 L98 jus wit a magna flow stainless steel catback an a y pipe????????????
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
