I'm back....have a q???
Old Oct 30, 2005 | 08:18 PM
chevyboy07 91's Avatar
hey all, been away doing the ARMY thing for what seems like forever.
Time to finish my Z and here is the list ...and a couple q's?
1. Crane 1.6's (gold)
2. some sort of TB other than stock
i see 52mm's everywhere for cheap.....my stocker im sure is killing me. she's running in the 12.30's as it sits with mods in sig (on motor)...i do also run a 250 shot on it as well....so should i get a 58 mm or will the 52mm be good enough? my concern is my K&N mounted at the TB. for the 58 mm TB i will need a new one (larger base) and im not so sure it will fit between the T-stat housing neck and all the other junk thats sitting right there....plus i have a fogger mounted nicely in the current filter so i would like to keep it. The other problem is that it apparently only flows 600 cfm??? is that true??? i think it is better than that! The other K&N is advertised to flow 1K cfm...i dont need 1k but surely 600 is choking the 383
