tpi help
Old Oct 31, 2005 | 08:32 PM
CRECLE's Avatar
Car: 87 iroc z
Engine: 350 tpi
tpi help
can you convert a tpi engine to an carbed engine? and if so what would it take to get it running?
Old Oct 31, 2005 | 10:28 PM
CRECLE's Avatar
Car: 87 iroc z
Engine: 350 tpi
all you people here and no one knows?
Old Oct 31, 2005 | 10:33 PM
cyrius's Avatar
Car: crossbreed
Engine: 350 4 bolt
Transmission: TH350
Axle/Gears: 4.56
utilize the search function, read through the wealth of info and start working on the swap. when you run into problems post pics with a detailed explanation as to your problem and you will be helped.
oh and for the answers
yes it can be swapped.
it would take research and work.
Old Nov 3, 2005 | 10:42 PM
net_coma's Avatar
Why do you want to make the change to a carb?
Old Nov 7, 2005 | 08:04 PM
kevinc's Avatar
Car: 1982 Z28
Don't confuse not knowing with not caring enough to answer...for the 1,000,000th time.
Old Nov 7, 2005 | 08:17 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
yeah it can be done but why the hell would you do it?
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
