0-60 or 0-100 PSI Fuel Pressure Gauge???
Old Nov 1, 2005 | 12:00 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
whicj one should i get? the 0-60 is easier to read but will i need a gauge that goes higher?
HSR on a 383, 30 lb injectors, and a walbro 255 fuel pump
Old Nov 1, 2005 | 12:29 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Shouldn't *need* a gauge that goes higher, unless you are boosting the engine somehow. If you're after better accuracy, a gauge is most accurate in the middle of it's range, but with 0-100, you lose resolution. But, in reality, an engine with a vacuum referenced fuel pressure regulator will have pressure from 33-44 for normal settings, which is about 50-75% range on a 60psi gauge, and you'll be able to read it easier, and not be too far off on accuracy. Most aftermarket gauges for fuel pressure aren't worth much for accuracy anyway, though.
In short, get the 60.
Old Nov 1, 2005 | 02:11 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool thanks, thought so but needed some assurance!
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
Kaweh
Aug 9, 2015 02:54 PM
