Need Help choosing intake......
Old Nov 9, 2005 | 07:54 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
Does anybody here have a FIRST intake manifold? It looks like it might be an option for me after I build my 355 this winter.
I plan on using vortech heads and some sort of TPIS cam on my engine with atleast 9.5 to 1 comp...I still havent worked out some details yet
and yes I did a search and found crap...I had a rough day at college today so I didnt look too closely
I would also consider any other manifold really as long as I keep it under $650 i might go more if i have to.
Old Nov 9, 2005 | 08:07 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It sounds like maybe you're planning to build a sleeper?
FIRST might be hard to find. I think you'd have an easier time finding some other large tube runners like AS&M, and a used Accel or bigmouth base.
The Holley Stealth Ram is cheap but there goes the sleeper look.
I think most of the other intakes out there will blow your budget.
Old Nov 9, 2005 | 08:13 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
yes i want something that looks and sounds "stock"....most ppl wont know whats different off hand when i pop the hood if i go with large tubes
I dont want to hear about not going with the long runner style intakes and how minirams stealth rams and all the other rams are the king **** of everything....
i am building a street engine for stoplight to stoplight runs so I need the torque well its more like i want the torque
Old Nov 9, 2005 | 08:17 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The large tube runners and bigger base plus vortec heads should be a good combo for you. The LPE 216 cam should be a great match for that as well.
Old May 26, 2006 | 01:33 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
if you plan on using the vortec heads you should look into the ram jet
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
Victor6
Aug 30, 2015 02:09 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
speedtendancy
Aug 25, 2001 01:30 PM
