TPI Swap...Fuel Pump Question
Old Nov 12, 2005 | 07:48 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
If I'm swapping in a 305 TPI motor into a 1992 Camaro with the 3.1 V6, is it necessary to swap fuel pumps?
I was reading and it seems the 3.1 V6 also runs the same fuel pressure as the TPI so I would assume it would work but I thought it would be better to ask. Sure would be nice not to have to go through all that hassle if its not necessary.
Old Nov 13, 2005 | 10:50 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
They're the same pump and you're right, the V6 and TPI cars use the same fuel pressure.
Old Nov 13, 2005 | 11:17 AM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
they are $60 from autozone
Old Nov 13, 2005 | 04:57 PM
Car: 1992 Camaro
Engine: 350 miniram
Great, thanks for the replies. I guess this will be even easier than I thought, now that I don't have to worry about droping the gas tank to swap pumps like the TBI guys have to do.
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
