TPI very high idle -- HELP
Old Nov 27, 2005 | 09:22 AM
peteg62's Avatar
i have a 1989 formula 350 tpi
upon startup car idles fine. after a few minutes it idles higher and higher until it reaches 1500 to 1800 rpm in partk.
I can be driving normally and all of a sudden my idle kicks up and keeps going up higher and higher , an nothing will make it come down except the a/c will kick it down somewhat.
wtf, I changed and adjusted tps sensor to 5.4 and I alcso changed the IAC valve to no avail.
My son has a camaro and I've swapped out oxygen sensor and thermo sensors from his car but still the same problem.
I need advice please.
Thank You in advance .
Old Nov 27, 2005 | 11:09 AM
Vader's Avatar
When you replaced the IAC, did you also set the throttle minimum air position?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
