Dyno Results
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Dyno Results
My dyno numbers are 370rwhp @ 5700rpm- 401rwtq @ 4800rpm. What kind of e.t.'s should the car make and who has simular numbers?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
370 rwhp and that torque should trap higher than 109.
330rwhp ls1 cars do 109 if driven right. u have 40more hp. and alot more torque.
i'd say low 12's at 112
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Check my sig. (Yea, I think my car should be faster)
Your car should easily run into the high 11s with a good 60' time and the trap speed should be about 114mph.
ir-regardless of your sig.
BTW: is this a trick question????
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Vincent just had his car dyno tuned. He picked up a little power and torque. Those are his new power numbers but the times are from the pre dyno tune.
I don't think he will have any problem getting into the 12.4's. He is racing at California Raceway which does not have the best traction in the world and is not among the faster tracks.
He is doing quite well considering it is a 355 and completely California smog legal.
I might add that Dyno Don is turning out some good motors. There are a couple comming down the pike that out to put down some good numbers.
No, this is not a trick question. I'm just curious to know what kind of e.t.'s some of you are running with simular numbers. I just dyno the car 11-26-05. My e.t. in my sig was before the dyno. California Speedway 1/4mi track elevation is about 1800 above sea level.
Ok! Here's my Graph. Dyno Don posted my graph for me.
What do ya'll think? The e.t.'s was done before the dyno. A new chip was burned after the dyno. No new e.t. yet.
Car: '87 IROCZ
Engine: 395 ZZ4
Those are great numbers.
I dont know anything about altitude and ET effects. But, I still believe that if you ran the car at Norwalk, Ohio, you would be in the 11s.
A dragstrip at 1800 ft is going to have a noticable effect on ETs.
Does anyone have a good relationship between ETs and altitude?
I think at sea level the car should run in the low 12's around 113mph. That's my goal I hope!
Car: 1989 GTA
Engine: 369 TPI
He is running a MAP setup. It was during our club dyno day so he only got a few adjustments in. He has more power in it with some more tuning. He will post when he sees your response. I'm just confirming his post.
I will also say with a few more mods and a little tweaking he might hit 400RWHP. All with a California smog legal 355 and very streetable as he takes the car on cruises with the club.
I will also say with a few more mods and a little tweaking he might hit 400RWHP. All with a California smog legal 355 and very streetable as he takes the car on cruises with the club. Thread Starter
Originally posted by DON 88T/A
VincentZ28...I assume you are running a maf set-up?
How much Dyno-time did you need to dial the car in?
Great #'s BTW.....
Great #'s BTW.....
LT1Formula
Oct 8, 2015 08:34 PM
