failed emssions test
Old Dec 1, 2005 | 05:34 PM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
both co and hco dont know why car runs drives great does not smoke or eat gas. havent tried anything yet just wondering what are a few thingsto start with.
Old Dec 1, 2005 | 10:32 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
what kind of shape is the exhaust system in? especially the cat
also check for o2 sensors and such
Old Dec 9, 2005 | 06:12 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
You have any mods that might effect it? Car running good? How bad did it fail post you readings. I just failed the other day for the same. Bastards keep enforcing the test making it harder to pass. First time i pass with no main cat just puppy cats. second time i failed which was like 2 weeks ago. I cut fuel, retard timing from 6 to 4, increased my temps all via ECM. And i slapped a cat on it. It passed pretty good then.
Old Dec 16, 2005 | 01:39 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, need to know how bad you failed. If it's close you can crutch by adjusting the timing, adding some rubbing alcohol to the gas tank (1-2 pints), and lowering your fuel pressure.
Make sure you run through when the car is fully warmed up too. Keep it running in line before you go through so it's fully warmed up.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
