LT1 intake on TPI???
Old Dec 11, 2005 | 09:09 PM
antman985's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 5.7L V-8 (Ram-Air)
Transmission: TH700R4 with stock 2.77
Hey guys i was wondering if an intake from an LT1 can fit on a TPI and if so what would be needed to make the change besides the obvious LT1 intake? Is it possible?
Old Dec 11, 2005 | 09:19 PM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
definitely will work as i am in the process of putting mine on right now! you need a hole drilled on the rear of the manifold for the tpi distributor (which needs to be a small cap in order for it to fit) and you will also need coolant passages drilled due to lt1 heads being different than tpi heads. also you will need the lt1 fuel rail and a remote thermostat housing. the whole lt1 conversion topic has been discussed on here many times so whatever you need to know do a search on it and TGO has the answer. being as the owner of lt1intake.com is frequent on these boards and of course he has all the answers!! good luck with it!!
Old Dec 11, 2005 | 09:58 PM
antman985's Avatar
thanks for the info!!!
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
