Removing EGR - Quote from "Corvette Fuel Injection" book
Old Dec 14, 2005 | 04:39 AM
S10Wildside's Avatar
The author of "Corvette Fuel Injection & Electronic Engine Management" (ISBN 0-8376-0861-9) writes...
The rate of fuel injection, and the spark advance are calculated for EGR under part-throttle conditions. If you block off the EGR, you stand a good chance of experiencing knock and wasting fuel. You might even lose power output, and you are dirtying the air!
Any thoughts on this? Specifically about losing power and increasing possibility of knock?
Old Dec 14, 2005 | 06:08 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
When the ECU is commanded to turn EGR on in a Speed Density system - it A) Reduces the calculated VE term and B) adds spark advance. MAF should only need spark advance.
EGR in nature (MAF and SD/MAP) will will reduce the throttling losses by a small percent. It requires slightly more throttle angle for the same power. That is where the slight fuel economy difference comes in.
The spark advance is there (MAF or SD), as well, which will bring it closer to knock, but if the knock sensor works, it won't bring any significant trouble to most.
But, if you do your own chips, you can disable it properly, and the economy difference is nil according to those that measure there economy and have disabled their EGR (I disabled it, but drive (drove I should say) in the city mostly, plus mine was malfunctioning).
Old Dec 14, 2005 | 12:57 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What he said.
Disable it properly thru tuning and go from there.
Just blocking it off or otherwise disabling it wont stop the ecm from running its functions when its active.
later
Jeremy
Old Dec 14, 2005 | 06:56 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Removing EGR - Quote from "Corvette Fuel Injection" book
The wording... spoken like someone who has never done it themselves.
Old Dec 14, 2005 | 07:00 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You will not lose power. Some people report getting knock with no EGR... I have never. If you do a good job of tuning after blocking the EGR you will have no problem anyway.
Old Dec 14, 2005 | 07:29 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Re: Removing EGR - Quote from "Corvette Fuel Injection" book
I have EGR, but its not from an EGR valve. The cam overlap in my engine gives me EGR. Same thing, just not controlled at idle like an EGR valve. Anyone ever opened up an EGR valve at idle on an engine (grabbing the underside of the valve and lifting), it runs just like a cammed engine. Big Cam with more than stock Overlap=Internal EGR (LT4 corvette)
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
