LT1 Injectors ANd AFPR
Old Dec 19, 2005 | 07:20 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Now That I Got My Lt1 INjectors IN My L98, What Should I Set My Fuel Pressure at? WIll 42 psi still be good? or do i have to go a little bit less since the LT1 INjectors flow more?
Old Dec 19, 2005 | 07:30 PM
Shagwell's Avatar
Car: projects.......
start at 42 and see how it runs. Then try bumping a few psi. - again, see how it runs. Evry car/motor is different. Also, w/ higher flow injectors, its never gonna be perfect unless you have the chip changed to compensate.
Old Jan 7, 2006 | 07:58 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Ok Got My Injectors In, And My Car Wont StarT! I Replaced The Vaccum Lines, COnnected ALl The Injectors, COnnected The MAF Back, Checked The Fuses And Still Da Same! Does It Matter WHat Connectors The Fuel INjectors Got? Or Do They Need To Be Connected As Same As The Firing Order
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
L0tuS
Sep 4, 2015 11:16 PM
355tpipickup
Sep 4, 2015 05:32 PM
