Rocker Ratios
Old Dec 28, 2005 | 07:49 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Rocker Ratios
I have a 350 TPI with the stock 083 heads... they have been machined for screw in studs and guideplates, however the valve guides have not been taken down any. I am running a GMPP zz4 cam, and I was wondering if I should go with 1.5, 1.6 or a mix? If a mix, use 1.6 on intake or exhaust?
Thanks.
Old Dec 28, 2005 | 09:27 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Just my two cents worth. Those heads are probably flowing about all they can now with that cam, adding a bit of extra lift probably won't give any more flow or power. And I'd say you're at about the point the guides will hit the retainers now anyway. On my car with Felpro seals the stock cam put the retainers right on the top of the seals. Not much extra clearance there.
Old Dec 28, 2005 | 09:30 PM
MattODoom's Avatar
Car: '88 G T/A
Oh, I forgot to mention, the heads have been really worked over both in the port and in the bowl. Also, the motor was mocked up with a low tension spring and retainer to guide clearance checked and was good, without the head gasket. I figure I should be safe with 1.6 by the time I get the gasket on. I dont know though, think I should play it safe and stick with my 1.5s?
Old Jan 10, 2006 | 06:45 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
If you mix the ratio's I have always read about people going 1.5 on the intake and 1.6 on the exhaust.
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Damon
Sep 26, 2015 04:29 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
