TPI runner balls
Old Dec 30, 2005 | 10:29 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Axle/Gears: 3.23 posi 10 bolt
TPI runner *****
I'm about to buy a chrome steel ball from www.mscdirect.com to use for knocking small dings out of my runners. These sell on ebay for $45 for a set of 4 or 5. I'll let you know if one will do the job.
This is from the MSC cart;
Items in Shopping Cart:
qty. item
number your
price extended
price special
notes in stock* delete
Line 1. Chrome Steel ***** Material: Chrome Diameter: 1-7/16
00072983 $14.84 ea $14.84 -- Yes
Sub Total: $14.84
Old Dec 31, 2005 | 09:16 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
let us know how it works out
Old Dec 31, 2005 | 09:19 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Guess why they sell 4-5 on ebay.
Figured it out yet? It's because you need 4-5 for them to work. Just pushing that through by hand probably won't work, and using tools risk damaging the part you're trying to save. Good luck although its probably cheaper just to get a used set in the classifieds without dents.
Old Dec 31, 2005 | 10:12 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yeah you need more than 1, i bought some off ebay, they take out big dents, nothing else, wasnt really satisfied, bought accel large tubes
Old Dec 31, 2005 | 10:20 AM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
Why not buy SLP runners, I got mine delivered for 273 dollars. Ther stock runners suck BIG TIME, maybe the worst part of the setup(as the base really sucks too). In my opinion fixing the horrible stock runners is like buying a diamond ring for a crack *****, or as useful as flushing it down the toilet. The SLP's would give you a solid 10-12 HP and much more if you upgrade the base. I just hate to see people waste money when a little more would put a big smile on your face when you floor it.
Old Dec 31, 2005 | 10:25 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Wasn't thinking of fixing them performance wise just get the dents out for looks.And my combo runs better times with the stock runners than the ported SLP on the 305
Old Dec 31, 2005 | 10:49 AM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
Thats hard to imagine, I saw several SLP runners installed when I was in Lincoln Tech and they did before and after dyno pulls on all 5 cars which had various work, but the worst I ever saw was 9 RWHP increase on a stock 305 firebird, 3 were modified and made 12-18 RWHP depending on the car. Why would your car run faster with an intake that stops flowing at 4700 RPM? Or is the sytem modified in other ways that I don't know about? Maybe TPIS's Large tube runners instead? But I am still lost as to why your car would run better with a worse flowing set of runners. Any car from a Honda to a Ferrari will create more power from a more free flowing intake? Please do explain.
Old Dec 31, 2005 | 11:20 AM
Car: 86 T/A
Engine: HSR 355
Probably leaned out his AFR.
Old Dec 31, 2005 | 11:26 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
can't really explain but I've switched between the SLP's that came with the ported intake system from a board member here back to the stock one's that I gasket matched to the ported & siamesed plenium and it runs 2 tenths faster with the stock runners on my set up.Been switching them back & forth for over 3 yrs now with the same results.
Old Dec 31, 2005 | 11:31 AM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
Wow thats crazy. One thing, you said you had a siamesed plennum, how with stock runners? Wouldn't it just be a solid flange? That would defeat the purpose of the siamese wouldn't it?
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
And these are the stock runners since I've been the only owner of this IROC.Have made over 10 runs in the 13's with the stock runners but with the ported SLP's never better than 14.0's
Old Dec 31, 2005 | 11:41 AM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
What are the 60' times, my only guess could be that the smaller runners are giving you a tad more low end torque and could improve your 60' x's, but then your trap speed would be lower? Maybe the port work on the plennum kind of messed it up if not done properly, it really is an art, because there is no other explanation, a higher rev limit should lower your times, that really is weird???
Old Dec 31, 2005 | 11:45 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
1.9 60' w/ both runners...only thing I could come up with is the velocity of the air is making the difference
Old Dec 31, 2005 | 04:55 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
I'm fairly creative with metal, so who says you need 5 STEEL *****. I'm confident it will be fine for my little red wagon and i'll lose the stinkin' holley.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Chiknhawk
Aug 23, 2015 05:54 PM
Sanjay
Aug 12, 2015 03:41 PM
