86 T/A TPI Air Inlet Assembly
Old Jan 20, 2006 | 06:03 PM
Galen W Rouse's Avatar
Car: 1983 Trans Am 1986 Trans Am WS6 1985 Fiero SE
Engine: 83' LG4 305 86' 5.0 TPI 85' 2.5 Fiero
Does anyone make an Air intake to replace the restrictive box and Tubing in an 86 T/A with a MAF TPI? I have looked with no luck so far. Thank You
Old Jan 20, 2006 | 06:54 PM
TheNuge876's Avatar
Car: 1986 Trans Am
SLP Makes an induction kit, its a couple hundred dollars, also if you search around on the internet or probably this forum you a can find out how to make your own for a lot less.
Old Jan 20, 2006 | 06:58 PM
Vader's Avatar
That system really leaves a lot to be desired, doesn't it? I have the same problem, err, "opportunity" on my '86 TA. I've found a place that offers lots of custom intake pieces, but haven't yet tried it myself:
http://intakehoses.com/
Old Jan 20, 2006 | 07:27 PM
Vader's Avatar
You could also get this part from the dealer:
That's GM P/N 25147187, about $53.00 It is produced with a small hole at the outer edge of the elbow, which would either need to be plugged or might make a suitable location for a relocated MAT/IAT sensor.
To complete that portion of the project you would need one of each of these items:
Sensor, Intake Air Temp P/N 17111662, $11.48;
Connector, Sensor, AIT, (2-Way female) P/N 12102620, $13.84;
Connector, Sensor, AIT, (2-Way male) P/N 15326386, $13.85;
Five feet of AWG16 wire in your favorite colors.
Wire the connector to an extension harness, connect it to the existing plug next to the distributor, and abandon the old MAT on the underside of the plenum.
Then adapt the duct elbow to the MAF sensor on the other end with the products at the above web site, or any piece of plastic pipe.
Old Jan 20, 2006 | 07:58 PM
TheNuge876's Avatar
Car: 1986 Trans Am
Yeah the SLP one does, especially since its still underhood. But it was the only one I could think of off the top of my head, adn if your on a really tight budget you can make your own. Otherwise I'm sure there are other options to be found if you can find custom pieces.
Old Jan 21, 2006 | 08:28 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
I found the most restrictive part on the 86 TA was the canister.
I removed the canister, took the stock paper air filter amd taped a piece
of cardboard over one end, and it wiggled right on the end of the
MAF. I then test drove it, and it made a bunch of difference from
4000-4500 rpm.(The peanut cam is out of power at 4500).
I then changed to a K&N. Inside the canister itwas still falling
down in the 4000-4500 rpm range. I then put it on the end of the MAF
as before, and it woke it right up. I could not notice a big improvement
with the K&N over the paper when it wason the end of the MAF, but I
am sure there was some. I then removed the plastic piece that goes
from the bellows to the MAF and replaced it with a 3 inch piece of exhaust pipe.
(Change to a elbow at this point). In seat of the pants testing,
I did not notice any more performance than thru the black plastic piece.
(That's with a K&N filter.) My total cost was under $10.00.
Old Jan 21, 2006 | 08:30 PM
Steve86TA's Avatar
Car: To many to list
For a cheaper alternative use an 88-89 tpi air intake tubes.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Sep 7, 2015 01:37 PM
Sanjay
Aug 12, 2015 03:41 PM
