more questions
Old Jan 21, 2006 | 03:37 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
more questions
anybody know where I can get a tweaked chip for my 110 lobe sep. cam that I am using in my MAF asperated setup?
Can a larger "increased flow rate" maf sensor be purchased for my 86-87 TPI unit?
Can I do this?:
Run a by-pass tube past my MAF that will have a butterfly valve operated by a solenoid whose relay will operate off of a vacuum switch. The TPI air flow would flow through the MAF totally until The vacuum switch opens the butterfly and then both paths flow air into the plenum. I am putting TPI in my 84 T/A and on my old carb set up it had a vacuum operated cold air intake on the hood. I was going to use that hardware to make the by-pass tube actuator if the idea will help my flow restriction issues.
please advise
thx
jeff
Old Jan 21, 2006 | 04:36 PM
jjlabinski's Avatar
Engine: shinny 350
I found granatelli part#350100 adjustable MAF.
does anyone have feed back on that part?
Old Jan 23, 2006 | 07:20 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
hit up Midamerica, even thought they are vettes there MAF will wrok with what you need.
IMO i'd custom program, spend your money that way. you can even remove the screens then reprogram your chip to it You gotta a cam i'm sure she's still not gonna run right with out a good burn or not to par.
Old Jan 23, 2006 | 08:54 PM
Shagwell's Avatar
Car: projects.......
a buddy of mine(Dans87GTA) is running 220/230 @ .050 497/502 on a 110. He's still runing the stock 87 L98 MAF tune, even now with his HSR. Not ideal I know, but mid 13's....yes, you should get it tuned, but not mail-order. Either do some research and get the tools to DIY, or pay the $ to have it dyno tuned...
Old Jan 24, 2006 | 07:56 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
What hp did that guy get out of that setup . i am curious . I got all the mods in my sig and netted a 251/318 rwhp and tq
Old Jan 24, 2006 | 11:26 AM
Shagwell's Avatar
hasn't been dyno'ed. - gets 22mpg highway and runs mid 13's though...not bad for stock chip/mild motor...
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
