Dyno results
Old May 7, 2006 | 03:33 PM
  #51
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Forgive me for coming in on the tail end of this thread.. I'm nearing the end ( or never ending) TBI to TPI swap with a Comp Cam xfi 230/236 as well. I(t's in a93 Caprice Wagon. I have two questions.
First off, I didn't notice the injector size lb/hr rating posted in the thread. I'm having trouble with 32 lb/hr as being overkill and fouling plugs within minutes. Knowing what you were successful with would be great help to me.
( By the way the grind # for the 230/236 is 08-467-8, also identified as CS-280XFIi HR-13. I've got the grind card in front of me.)
Although I'm on a speed density 730ECM, The VE table (fuel curves) and Spark advance should be in the ballpark. I'd love to see those tables! Can you a shoot a copy of the .bin file to me? $? You mentioned that you self programmed the system.. using what program and tools. I've got TunerproRT now and have been thibnking the prominator route.
Full disclosure:
1993 Caprice Wagon ("Shammoo" ex Kicker demo car) 5.7L, Comp Cam XFI 230/236, Accel 32lb/hr injectors. , SLP siamesed runners(not yet matched to) stock plenum and base, AFR 195 heads with Proform 1.6:1 rockers.Shorty small tube headers, dual cats , speed density 730ECM
currently residing "quietly" in driveway.
Dave Buchholz,Rochester NY
Old May 21, 2006 | 04:44 PM
  #52
TheKeeling's Avatar
Car: 1985 Z28
Engine: 5.7 TPI Crate Motor with Vette PROM
Axle/Gears: Richmond 3.42
Went with my friend to get his 86.5 turbo supra dyno'd, around 290 hp and torque! not bad! I really wanted to dyno my car, but I need to break the crate motor in..... only have about 250 miles on it so far
Old May 22, 2006 | 09:52 AM
  #53
Guest
Guest
Posts: n/a
I'm running 30# injectors, idle PW numbers are on the low side but manageable. Smaller injectors for this particular setup would probably make more sense but I had/have other plans... and then the 30's are probably going to be too small.
I've been doing tuning lately with Tunerpro and Autoprom, but before that I was burning and editing code mostly with a hex editor.
Old May 22, 2006 | 12:56 PM
  #54
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"I had/have other plans". Hehehe. Can't wait to see what they are. Going to be some high powered cars here in good ole So Cal.
Old May 22, 2006 | 01:00 PM
  #55
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
And Northern Cal.! I am having way too much fun.
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
