Idle me this! Idle me that!
Old Jan 23, 2006 | 07:21 PM
zrated57's Avatar
I hope this is the correct place to post this question. I have an '85 Z28 with a 5.7 TPI. When I first start it up it wants to idle at 1500 for about a minute then it will slowly idle down and then jump around a little before it finds its calm.
Also, I notice that when I first start it up and the engine is still cold (meaning the temp. gauge hasn't moved at all yet) I step on the gas and it wants to stumble and hesitate before taking off. What would anyone recommend? Thanks
Old Jan 23, 2006 | 07:26 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Replace IAC, clean throttle body good, recal the TPS. before jumping into it check for codes first, check IAC counts at Idle should be 30-50 or so too.
Old Jan 23, 2006 | 08:11 PM
zrated57's Avatar
Can you send or post TPS recal. instructions. Maybe there is a link.
Old Jan 24, 2006 | 03:38 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You will find everything you need to know in the technical article section thats on the home page of this site.
Also, do a search, you will find more than you ever bargain for!!!!
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
