19lb injectors on an L98
Old Jan 24, 2006 | 02:30 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Has anyone used Ford 19lb injectors of an L98/350?
Do they work or not enough fuel pressure?
Its for a 1990 IROC the original 22lb'ers are toast I tried 24s but I think they are giving some trouble.
I found a new set of Ford 19s cheap so figure I might try them?
thx
Old Jan 24, 2006 | 03:30 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you run them at 54 to 56 psi fuel pressure, they will flow nearly the same as GMs 22s. The ECM should not have a problem with this setup.
Old Jan 25, 2006 | 01:57 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
What abotu the STOCK fuel pump , will it like that high of PSI ?
Old Jan 25, 2006 | 02:30 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
Hey.
Our L98 still has 19s in it from before the death of its transmission. We ran 48psi on a new Holley 255lph pump and there wasn't a hiccup. The mods: AFPR, the aforementioned pump and injectors, upgraded coil/cap/rotor, and a 3" catback.
FWIW it knocked down nearly 28mpg on a Tahoe trip and never missed a beat with the F0rd injectors in it. HTH
K
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
