opinions on this cam?
Old Jan 28, 2006 | 12:01 AM
CamaroCrazy23's Avatar
Car: 1991 Z-28
Engine: AFR ELIM 195s,280xfi,58mmLt1 Intake
Transmission: 2200stl,700r4 shift kit,vette servo
Axle/Gears: 28 spline, 3.42 gears, SLP Posi
Adv. duration 287/287, duration @.050 226/226, Lift .520/.520. 112 LSA.
its for a 383 with ported and polished heads that flow about 225 @ .600 lift and this cams opperating range is 2000-6000 the max my engine will ever see is like 6300 rpms. I've got about a 2500 stall through my built 700r4 and the air will be pushed through a converted lt1 intake with 28.5# ls1 injectors and running around 50 psi of fuel (just a guess b4 its tuned for WOT)
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Jlanz55
Sep 8, 2015 11:28 PM
TheExaminer
Sep 7, 2015 08:34 AM
Strick1
Sep 4, 2015 07:11 AM
