mass air g/s
Old Feb 4, 2006 | 06:00 PM
joeyg329's Avatar
Car: 88 iroc/383 82 regal/sonoma 4.3 5sp
Engine: 5.7 tpi/383/4.3
Transmission: 700r4,th350,t-5
mass air g/s
ive posted about my rough idle, and have done alot to try to even it out, but i was data streaming the car and my mass air is reading 6 g/s at idle, and goes up slowly when i rev the car. with the car off and the scanner pluged in it reads 14 g/s. unplugging it or tapping doesnt do anything and the car is throwing no mass air codes, but it used(6 months ago) to throw alot of burn off relay codes and i have replaced them 3 times. ive done what loudmouthss told me as far as the idle recal with the new cam, but the car still wanders low in idle and is not a fast as it could be. Is my mass air going or is that normal readings for the sensor? im trying to rule out alot of possabilities and get this car going.
and on an added note my master cylinder is leaking, just something else to annoy me while i deal with this problem.
once again thanks
joey
Old Feb 5, 2006 | 03:19 PM
Guest
Guest
Posts: n/a
Sounds normal to me.
Low battery charge can trigger a code 36, may have been the issue with that.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
