heads for a 305 tpi
Car: 1989 Pontiac Formula
Engine: 305 tpi
heads for a 305 tpi
I was wondering if it would be better to port and polish the heads on my car now or to buy a new set? But the thing is I dont know where to look for 305 tpi heads. Help Please.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
If you are mechanically inclined and do your research you can port the heads that are currently on the car. 305 tpi heads are no different than any other 305 heads cast after about 1981 so finding heads is not an issue. Or you can buy aluminum L98 heads like I did. see the sig. Also do a search for this topic. It has been covered extensively on this site.
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
You'll find that it's about the same cost to rework your old heads as to purchase new ones. World Products makes S/R Toquers for a 305.
Sanjay
Aug 12, 2015 03:41 PM
