Lt1 head & intake cam advice?
Old Feb 7, 2006 | 06:16 PM
firehawkslplus's Avatar
Car: 91 Firebird Dark Green
Engine: 350 Victor Jr. 2V 2000 CFM TB EFI
Transmission: 700R4 BM 2500 stall
Axle/Gears: 3.73 Zexel torque sensing Posi
While I've got the eng out (l98) of the Firebird (91/TPI). I've decided to go thru it since the whole quick in/out didn't happen and I've got beater to drive daily.
I'm going to do the LT1 top end conversion (heads and Intake). What I hope is for some advice on cam selection.
STOCK L98:INT.202/EXH.206 = LIFT.403/.415 = LS115DEG
H.O. ZZ4 : INT.208/EXH.221 = LIFT.474/.510 = LS112DEG
LT1/4 HOT : INT.218/EXH.228 = LIFT.525/.525 = LS112DEG
Basiclly a stock type rebuild on the lower end, arp rod bolts, main studs, hyperuetic (?) pistons, ect. A good DD set but with pwr output more inline with some of the newer eng. I'd like to see something around 300hp. As it stands ZZ4 looks pretty good and the price is right.
Old Feb 7, 2006 | 06:41 PM
Vader's Avatar
I like the duration on the ZZ4 cam a bit more. Are those lifts for the ZZ4 with 1.5 rockers? The lifts of the LT4 "Hot" cam are with 1.6 rockers.
Old Feb 8, 2006 | 06:24 PM
Those numbers are w/1.5 rockers. I would actually be using some 1.65 self aligning alum. RR.
Old Feb 12, 2006 | 12:50 AM
Re: Lt1 head & intake cam advice?
Ok i've got the Lt-1 intake, alum. heads and the Blk. ect. are out get machined.
Anyone have any more thoughts. The car is a 91 Formula 350TPI (map), 700r4/ 2400 stall shift kit, C5 brakes up Frt, 02camero disc br. posi w/3.23, whls 17x9 275/40-17 at all 4.
My brain says ZZ4 my gut wants LT-4HOT.
I drive 50mi mostly hiway daily.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
