tps wiring help needed
Old Feb 9, 2006 | 09:24 PM
86camaroguy's Avatar
Car: 86 iroc-z
Engine: 305tpi
ok i have an 86 tpi 305 my plug was removed and the wires just stuck in the tps i need to know which order the wires go in from top to bottom in order of color right know it is (starting from top)
black,blue and finally gray i got a switch off of a gm from a salvage yard not a tpi but the wires are gray,blue and black i just want to make sure it goes back together right thanks for the help chuck
Old Feb 10, 2006 | 08:35 AM
Vader's Avatar
If you inspect the connector closely, you'll see the letters "A, B, & C" adjacent to the terminals. The black wire goes to the 'A' terminal. Blue goes to 'B'. By elimination, gray goes to 'C'. Make sure you solder and seal the splice connections with either self-vulcanizing tape or shrink tubing.
Old Feb 10, 2006 | 10:14 AM
Car: 86 iroc-z
Engine: 305tpi
ok thanks that helps me out alot
specialized
Jun 18, 2022 09:26 AM
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
