new motor burns oil on startup
Old Feb 12, 2006 | 08:10 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Well ever since i got the 355 back from the machineshop...its always burned oil on start up. The guy got my heads too and he did the valve seals and all that stuff that would normally cause this. I know the rings need time to seat and whatever...but ive probably put near...500-1,000 miles on her now and i figure they should have seated by now (someone told me that could be causing the smoke too). Anybody have any ideas? it doesnt burn oil when driving at all or revving for that matter. Its only on start up.
Old Feb 13, 2006 | 03:17 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If its only on startup, I would look toward the valve seal area.
Maybe wrong oens were fitted or if anything was cut down or remachinged there could be issues.
Or some problem guides even.
More than likely a valve stem seal issue I would guess.
Specially cause u complain of it only on start up.
Nother thing to note, is the smoke bluish white or black? If its darker in color it could be a tuning or injector issue(didnt say carbed or inj)
later
Jeremy
Old Feb 13, 2006 | 06:25 AM
Car: 1991 Z28
Engine: SBC
its fuel injected. Wierd thing is sometimes i swear it looks grey...other times it has a bluish tint. And the smell is hard to describe, but i would lean more towords burning oil.
Old Feb 13, 2006 | 11:07 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I had the same problem. Ended up being crappy valve seals (they cracked and wore oddly) and 2 crappy injectors. Except mine never stopped smokeing after startup. It did it all the time. After replaceing all 8 of my stock injectors and a couple of hours replaceing all of the valve seals. No problem... Kind of embarassing when you tell people it has a new engine and it puffing out more oil than valvoline can produce.
Old Feb 13, 2006 | 11:44 AM
Car: 1991 Z28
Engine: SBC
lol yea i know..brand new 355 and she burns oil already
Old Feb 15, 2006 | 10:42 AM
Car: 1991 Z28
Engine: SBC
my mistake guys...its actually grey smoke. Sometimes its a huge cloud of it on startup...other times its a small puff and other times it doesnt do it at all. Smells like gas too...could it possibly be a leaky injector?
eightsixseven
Dec 16, 2024 01:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Exxon Limited
Aug 9, 2015 08:13 PM
