TBI to TPI
Old Feb 14, 2006 | 10:13 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
TBI to TPI
hey guys, i currently have a 92 RS that is TBI and i have a Tuned port setup just sittin in my garage i am going to swap on.....im tryin to find out what i need....i know i need new sensors and i have all of them..i have new throttle and detent cables pretty much everything except wiring....my question is wiring...i just need a fuel injection harness dont i...i dont need to re wire everything....cuz i was looking at the painless....any info would be great
Old Feb 14, 2006 | 11:16 AM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
I just did a TBI to TPI conversion on my 91' chevy truck. I used a painless wire harness. I simply unplugged all TBI connections and removed the TBI ECM. I did not rip the old wires out of the truck, I tucked them away. The only problem I ran into with the painless harness was the relays had to be about 6" from the ECM. I had room in the dash to do this, but you won't in a Camaro. Ask Painless if they offer a longer harness that allows the relays to be under the hood like a standard TPI camaro. I also wound up having to lengthen some of the connections to other sensors, but that was because of my truck accessories which wouldn't envolve your camaro ( I had to convert my Alt and Air brackets over to make room for the MAF and air intake). Painless included an addon wire connection for my distributor and coil, but I had to use the old wires that ran from the distributor to the coil, not a big deal. All my TPI cars have the smaller distributor with a remote coil, but Painless makes the harness to work with a distributor that has the coil in it!!!
Harness comes with good instructions, just study up on what you're doing and you'll be ok.
Make sure you hookup the ignition power for the ECM to an ignition that does not get turned off when in crank mode!!!! I spliced into the original TBI ECM inputs for battery, ignition, along with VSS, brake switch, and park/neutral.
Old Feb 14, 2006 | 11:31 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
ya i have the remote coil distributor...i may have some more questions in the near future for u....im gonig to go order the harness today...i believe im just going to use the painless chip that eliminates vats so i dont have to mess with that...ya i plan on just tuckin the tbi harness away...as for the splicing ill some questions for ya once i get to that lol
Old Feb 15, 2006 | 01:38 PM
jmiller's Avatar
No problem, I'll try to help. I didn't have to worry about VATS on my conversion because I used an 88' ECM.
Is the TPI system a MAF (86-89) or Speed Density (90-92)?
Do you have to smog it?
I successfully passed the smog test with my 87' IROC in California using AFR heads with no heat risers, meaning that the EGR valve I installed was sitting on a closed chamber! I also did the same thing on my truck by using an intake gasket that had a metal piece closing off the heat riser. I did this because I didn't want to worry about the EGR working properly. The smog guys can't test an EGR valve on TPI because they can't get to it!!! Both my vehicles run fine this way.
Old Feb 16, 2006 | 04:43 PM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
i have the Speed density TPI and ill be hooking up egr and all of that unless i just decided to delete it....i just wanna get the thing on there...i just have a couple more pieces to buy to get it together and then wait for the weather to warm up...i dont have a garage to use...its full lol
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
