computer chip problem?
Old Feb 17, 2006 | 09:22 PM
bigtom88transam's Avatar
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
hey i have a 305 trans am which has computer chip and it runs very rich....could the chip be screwing up computer to idle very rough??
Old Feb 17, 2006 | 10:25 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I'd try a new o2 sensor first.
Old Feb 18, 2006 | 12:44 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Check all the basics first
Than use a scanner to make sure all sensors jive when hot and cold.
88 still has cold start injector, that could leak, bad injectors could leak, weak ignition could cause it or a bad 02, failing temp sensor, etc
Check everything out and than see where u stand.
Try to educate yourself about what it is doing before u throw things at it.
later
Jeremy
Street Lethal
Apr 30, 2019 12:14 PM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Bryan F
Aug 18, 2015 02:28 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
