Fuel line
Old Feb 18, 2006 | 06:17 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Fuel line
Long story short. Fuel line from the tank down * at the crimp* has bend up, BUt I bent a new line with a union for the Special Fitting and seal all cleaned up and such, But..
For some reason the fittin has dissapeared
1. Go to a junkyard cut out another one
2. Screw it and get it fixed by a mechanic
3.Try to buy an oem line and o itmselg ( not thinkng i have the tools lol)
Old Feb 23, 2006 | 01:29 AM
Vader's Avatar
Do you have a diagram or photo? I'm not quite envisioning the exact line you are describing.
Old Feb 23, 2006 | 11:44 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
I dont have a Diagram or a picture as of now, Its The Feed Line from the fuel tank as far as i can tell, it comes from a Rubber hose, Into a Crimp Then steel 3/8 line down into the Fuel filter ( in port)
For quick removal i had cut the hose, So and *** forbid for having lost it, I bent up 3/8 line and put a union fitting to connect to the correct o-ring Part of the line, of course By the end of my shop day it had "dissapeared" So, Im curious what to do wether to take it to a mechanic or to fix it myself?
Old Feb 25, 2006 | 10:07 AM
Vader's Avatar
The pressure line from the tank - I've got it. You can get one from the dealer, or get the parts and fab one yourself.
Old Feb 25, 2006 | 05:40 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Does this involve taking down the tank? ( I have a 3/8 line bent up Just problem is i dont have that fitting that goes into the fuel filter Also the Crimp is cut, so all there is is a rubber hose ...
Old Feb 26, 2006 | 10:18 AM
Vader's Avatar
Unless you can reach the short steel tubing stub while the tank is attached, or adapt to what is accessible, you'll have to at least lower the tank a bit.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
