Wierd Engine Hesitation
Old Feb 19, 2006 | 02:25 PM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
350 TPI Vortec.....Fuel pressure before start is about 20lbs, after start(while running)with vaccum connected to regulator is about 38lbs...Recently changed the fuel filter. Now the problem is this while driving it the car will drive fine with about1/4 of the throttle depressed, but when I go to give it full throttle it hesitates for a few seconds, then suddenly feels alright and then goes back to hesitating again, Ive searched and searched but could not find anyone with a similar problem. Do my fuel pressure numbers look right? I was concerned with the key on/enging off fuel pressure. Any help would be greatly appreciated...thanks!!
Old Feb 19, 2006 | 07:41 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Is this vortec running a TBI induction on it? Your info suggests otherwise. If so what chip work have you done?
Old Feb 19, 2006 | 08:07 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
you should look in the TPI section they may help you out better since this is a TBI
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
