Knock Sensor
Old Feb 20, 2006 | 09:09 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Knock Sensor
If the knock sensor is activated and the timing gets retarded, should it not trigger a ses light every time???
Just curious. I'm trying to figure out why my 2nd '91 Z falls flat on its face.
There is some noise from the 157k mile 305, but I'm not getting a ses and there are no codes.
Old Feb 20, 2006 | 09:17 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
The "knock" triggering the Knock sensor and retarding your timing isnt going to set a SES in most cases.. It is just a monitoring tool..
could your problem maybe be that your cam is a little worn? ALSO- try going w/ premium fuel and see what happens..
My car only preforms a "knock" when it backfires through the straight pipes that are on it right now.. I can see this via my real time Diagnostic scan tool its a SnapOn MT 2500.. A very versitile tool- A $1600 setup. Ive seen them go on E-bay for like $200 w/ spare cartridges..
I could probably say more, but since im just a senior in high school i dont want to say something wrong and make myself sound like a complete moron..
Also- I've got a 86 305 with 127k on it that ran great. mechanically very sound, just burned a lil oil.. Someone told me to change the PCV valve and it'd probably stop.. but I went ahead and swapped my 358 w/ vortec's into my car..
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
