Harmonic Damper Question
Old Feb 22, 2006 | 09:44 PM
bonz's Avatar
Car: 89 GTA
I was wondering if and aftermarket damper is any better than the stock one. If they are any better I will get one but if there isnt any different I might as well stay stock. I dont pan on spending more than $200 on one if I do. Also what size would I need.
THANKS
Old Feb 23, 2006 | 01:19 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Are they better, you betcha.
Are they truly critical on a relatively low revving stocker.
Not really in a cost vs. performance standpoint.
Getitng into high dollar stuff or high revving and I would always consider it relaitvely cheap insurance at that point.
Best bet if a stocker, just replace it(if its bad) with a quality replacement and be done.
later
Jeremy
Old Feb 23, 2006 | 06:20 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
I think the best one is an ATI brand but, like 3.8 said, if you not going to be twisting it then a stock one would work just fine, but you may also look at a SUMMIT brand balancer, its a good bang for the buck, I think its about 189.00 or so the last time I looked, and its also an SFI rated balancer. Also make sure you have a install tool, thats the only way to really install one, I know some people used to just beat them on with a hammer and block of wood but thats not good. Good luck.
MoJoe
Sep 15, 2015 12:50 AM
gixxer92
Sep 1, 2015 04:32 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
