air pump / tube removal
Old Feb 26, 2006 | 09:41 AM
graphicideas1's Avatar
what is the trick for removing the rusted air tubes out of stock exhaust manifolds? They are on the car and i want to save them if i revert to going back to stock.
Old Feb 26, 2006 | 11:13 AM
Vader's Avatar
Apply penetrating oil to the fittings and tube joints. Keep driving the vehicle normally, and applying penetrant to the fittings daily if possible. Most of it will smoke/evaporate off, but some will penetrate the joints. The thermal cycling from operating the engine will help the penetrating oil get to the joints. After about a week of this activity, try breaking the fittings loose. More directly applied heat just before loosening the fittings may help. For those that refuse to move, apply more penetrant and allow more time. A lot of "impossible" fasteners and fittings can be freed this way.
I've done this with plain old WD-40, and had better success with B'Laster! PB and Altlas Heat Riser Valve Lubricant, although the latter is becoming increasingly difficult to find. Kroil is also a good product for this.
Old Feb 26, 2006 | 12:22 PM
how are the air tubes attached in back of the engine?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
mcquigg
Aug 13, 2015 02:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
