'89 TBI to TPI conversion?
Old Feb 24, 2006 | 05:39 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
What ECM part# will I need to complete my TBI to TPI conversion on my '89 Camaro?
Old Feb 24, 2006 | 02:42 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Depends on what set up you're going with. If you're doing a MAF set up you need the 7165 ECM. If you're going speed density you need the 7730 ECM. Go here http://www.chevythunder.com/ for some good info.
Old Feb 24, 2006 | 06:25 PM
ANDYZ28's Avatar
Car: 1982 Z-28
MAF
Old Feb 26, 2006 | 10:18 AM
ANDYZ28's Avatar
Car: 1982 Z-28
'88 and '89 TPI harnesses are the same?
Is the MAF TPI intake base different from Speed Density type?
Old Feb 26, 2006 | 11:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the '88 has the cold start injector, but that's a small wire or two. I'm not sure of anything else.
The 87-92 TPI intake manifold bases are all the same.
Old Feb 26, 2006 | 12:54 PM
vwdave's Avatar
From what I heard there is small differences. Cant remember them off the top of my head.
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
