Bolt-on Ideas?
Old Feb 22, 2006 | 03:21 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Bolt-on Ideas?
just looking for any bolton ideas. Not Doing Cam/Heads/Power Adder yet. Taking my car to get dynoed on 3/11. I have my current boltons listed in my sig below, just looking for any other ideas??
Old Feb 22, 2006 | 03:29 PM
Demon355's Avatar
you seem to have most of the mods already without digging into the heads/cam. I would say thats all thats left
More pics of the hood? Fitment issues?
Old Feb 22, 2006 | 04:05 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Post up the results.
Old Feb 22, 2006 | 05:21 PM
Mark 89Formula's Avatar
Tough to come up with much more than you've got. Some ideas. 1) Electric waterpump 2) clean-up/polish ports in the Edelbrock base (if not already done) 3) retard stock cam for additional top end using adjustable timing chain set.
Old Feb 22, 2006 | 05:40 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Tubular (or maybe boxed) lower control arms for rear end.
Old Feb 22, 2006 | 06:10 PM
Car: 89 Formula 350
Thanks for the ideas so far..I'll def post the Dyno results..... I'm hoping to hear good #'s but not gettig my hopes up to high.....this weekend I'm installng an LS1 Aluminum drive shaft and 1LE AC/Smog delete pullies..
Old Feb 22, 2006 | 07:21 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
skip the smog pulley
route the belt like an 89 full size blazer tbi
unfortunately i found that out after i did the pulley
advance the timing, thats trial and error, her car likes 13 degrees
only other thing i can think of if it's available is an aluminum harmonic balancer
Old Feb 22, 2006 | 07:57 PM
Car: 89 Formula 350
I already ordered the smog pulley so i'm gonna go with it.. I have my timing at a 13* advance aswell.
Old Feb 22, 2006 | 10:03 PM
bonz's Avatar
Car: 89 GTA
Didnt see a K&N air filter in the sig. I would get one of those if ya dont.
Mods. GMPP Vortec heads, Comp Cams XR269HR, Crane Gold Rockers, Hooker headers, SDPC intake manifold, free flow exhaust, Air Foil, TB Bypass, K&N filter. Future mods, TPIS Runners, AFPR.
Old Feb 25, 2006 | 05:18 PM
Car: 89 Formula 350
I have a KN filter already, Just installed the LS1 aluminum DriveShaft... Hope to see atleast 265 RWHP. I'll def post results.
Old Feb 25, 2006 | 05:22 PM
Car: ws6
Engine: ls1
Transmission: m6
265 would be 318 at the crank. You will probably make alittle more than that though.
Old Feb 26, 2006 | 04:31 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got 251 with my setup untunned ( ZZ4 cam ) , you should hit the 265 mark for sure with super ram
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
