mass air/adj timing set=problems?
Old Feb 26, 2006 | 03:16 PM
MULTpI's Avatar
Car: 89/92/94 s10
Engine: 3.4MPI/5.7TPI/2.8MPI
Transmission: NV1500/T-56/T-5
i did a quick search of past pots. didnt find what i was looking for. im in the process of upgrading my cam and runners and decided that i would replace the timing set. got a double roller timing set with 3 crank slots. -4/0/+4 degree increments. is there any positive gain of altering the cam timing beyond simply adjusting the dist? If im going to only gain problems i will simply put it straight up. its a crane cams compucam 2032 grind. if that helps at all. i would think that altering the timing this way would just cause problems but i wanted to find out from others in the know.
thanks in advance!
Old Feb 26, 2006 | 04:57 PM
joeyg329's Avatar
Car: 88 iroc/383 82 regal/sonoma 4.3 5sp
Engine: 5.7 tpi/383/4.3
Transmission: 700r4,th350,t-5
best thing to do is call comp cams... i just installed the same timing set and a slightly bigger cam in my iroc and i wondered the same, so i called them and i found out that my cam was ground to be 4 degrees advanced already, so i had to set it at the zero mark.. I would assume that all comp cams compu cams are the same idea so i would venture to say that u should install the gear at the zero mark. hope this helps!
joey
Old Feb 26, 2006 | 05:10 PM
MULTpI's Avatar
Car: 89/92/94 s10
kinda what i was thinking.. but thanks for the confirmation and the quick reply.
Ghettobird52
Jul 5, 2024 11:18 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
