holley AFPR
Old Feb 28, 2006 | 07:47 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
holley AFPR
those of you who have a holley AFPR does it take a while to start your car. I am talking about the number of revolutions that your starter has to make in order to start your car.
Old Feb 28, 2006 | 08:43 AM
730tpi's Avatar
Ya I had the same problem it turned out the diaphram in the holley regulator was bad. I bet your having the same problem. Start the motor let it run for a minute then turn it off and pull the vacuum hose off of the regulator and check for gas if there is gas in the hose that means the regulator has a bad diaphram.
- Justin
Old Feb 28, 2006 | 11:33 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
When my Holley diaphram started leaking I didn't see any fuel in the vacuum line. I jumpered fuel pump to run with eng off and still didn't get any leakage. When I pulled the vac line off with the eng idling, it squirted all over the distributor.
BTW: Holley sent me a new diaphram for free after I called them up.
Old Feb 28, 2006 | 05:19 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have a Holley AFPR and no problems reported here.
It seems that the only reported problem with the Holley is the diaphram. I dont know if its really any different than others or not.
RedLeader289
May 28, 2019 01:47 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
