will this hold up
Old Mar 2, 2006 | 07:56 PM
joshmack's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 377: comp 10.5:1
Transmission: 350 turbo- 8 inch Coan
Axle/Gears: 10 bolt-373
will this hold up
im thinking of buying 10bolt aurbon posi with 411 strange gears w26 spline will this hold up in my 89 iroc i currently have 11inch converter coan 350 turbo with rare borg warner reaend cant buy ringand pinion for with 277 gears but up graded to 8inch coan 4000 etstreets and cooler for converter. dont have alot of cash to spend 600 will buy the 10 bolt new posi and gears i know 9in or 10 bolt is better but dont have that much cash if axles break in the 10 bolt which are 26spline can ireplace with 28 spline, what do i have to do to do this
Old Mar 3, 2006 | 03:38 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Pretty hard to read your paragraph... Are you saying that you have a 9-bolt now?? I really don't know what you're asking.. Obviously, you can't buy a posi meant for a 7.5" RG 10-bolt and put it in the BW 9-bolt..
When you do buy a differential, you will be stuck with whatever axle size you buy it for (if you get one for 26 spline axles, thats all it'll be able to use).
Old Mar 4, 2006 | 09:44 AM
Shagwell's Avatar
Car: projects.......
If you buy the posi for 26 spline axles, then no, you won't be able to go 28 spline WHEN the 26's break. You'll be stuck w/ 26, or with buying another posi/locker to fit the 28 spline axles. Then you have the good axles and case and could still end up chunking a gear when the 10-bolt case flexs under power. - If you've got $600, live with the 2.77 until you have enough for a 9 inch or 12-bolt. Sounds to me like you're planning more than enough power to desintegrate a 10-bolt.
If you can't afford to do it right the first time, can you afford to do it again?
Old Mar 4, 2006 | 09:47 AM
Shagwell's Avatar
also, you should post this on the trans/drivetrain board, since it has nothing to do with the TPI...
RedLeader289
May 28, 2019 01:47 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
Briandrex
Oct 5, 2015 06:20 AM
racereese
Oct 3, 2015 03:46 PM
