36lb Injector Help
Old Mar 3, 2006 | 12:17 AM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
36lb Injector Help
Im looking to find a good quality 36lb injector that i can run in my tpi fuel rail. Im a little confused as to the difference between the FMS and SVO injectors. I can only find the FMS injectors in 19, 24, 30, and 42. I have seen 36lb SVO injectors for sale, but im wondering if they are the same dimensions. I have also seen 36lb LS1 injectors, which im wondering about their dimensions, and then there are the delphi injectors that i find at racetronix. Or what about 36lb bosch injectors, but those are similiar to the delphi or LS1 injectors from what ive seen
If anyone can shed some light on what injectors would be best i would appreciate it.
Old Mar 4, 2006 | 10:47 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Couple of different body styles of injectors. If they look like the ones you have now than they will fit. Make sure they are of high impedence. That would be in the neighborhood of 15 ohms. Low impedence are around 5 ohms.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
