What kind of fuel pump HELP ME PLS
Old Mar 10, 2006 | 01:54 PM
Camaro Hunter's Avatar
Car: 70 camaro
Engine: Building 383
Transmission: muncie 4 speed
Axle/Gears: moser
Can some one give me an idea what all it will take to convert my 70 camaro to a TPI car.
I already pulled a running 305 out of a 89 camaro It does have the 9th cold start injector. The motor is fully complete. I also purchased a wiring harness from painless. I did not grab the gas tank witch I wish I had. I am aware that I will have to run a return line. But what is the best way to get this motor in their.
Thanks Jeff
Old Mar 10, 2006 | 04:36 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
walboro 255 seems to work. Not sure if it will fit your tank but that's where i would start.
Old Mar 10, 2006 | 04:42 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I've seen a tank on ebay for a gen 1 camaro that was already modified. Have a look. It was a while back though. You can always run an inline pump but there are embarassingly noisy. I had one in my TPI converted impala and I ripped it out in a week!
Old Mar 10, 2006 | 05:31 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you got to buy a fuel pump, you might as well buy one as mentioned above, 255 liters per hour rating.
Old Mar 10, 2006 | 06:13 PM
Car: 70 camaro
Axle/Gears: moser
Will the return line for the fuel have to have back presure or can it be a free flowing hard line to the tank
Old Mar 11, 2006 | 05:49 PM
Rob Wade's Avatar
I just ran a 5/16 steel line straight back to the tank on mine. No problems.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
