MSD ignition wires for TPI
Old Mar 20, 2006 | 11:45 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
has anyone used these wires?
MSD-31409
how do they fit?
are they like banjo strings like the Accel 8.8's are for the TPI?
I have the 8.8's and they are extremly tight fitting, hardly any room to run wire sperators
I want to neatly lay the wires out and would like to use wire separators as well
what separators can i use with these wires? is there a spearator that bolts to the center valve cover bolts?
I also have 89 Full Size 5.7 TBI Chevy Blazer wires from MSD (brand new), was wondering if i could just use them?
they are 90 degree boots on them
the trucks used manifolds that went downward, the F-bodies used an upward manifold, so not sure if these would fit without rubbing/burning somewhere.
thoughts?
Old Mar 20, 2006 | 06:45 PM
Don 79 TA's Avatar
Engine: TPI
anyone used the MSD pre-wired kit?
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
tartagliaz28
Aug 15, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
