Edelbrock High Flo Base
Old Mar 20, 2006 | 06:54 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Are any of you guys who have the edelbrock high flo base using after market heads? Is there a different edelbrock base for stock L98 heads then for aftermaket heads(see on edelbrocks site they have one for L98 and one for aftermaket heads)? Doesn't the base have a duel bolt pattern so it can be used on stock L98 heads and aftermarket??? Anyone running that base with Brodix 200Ik heads?? I just don't want to order heads and find out the won't work with that base........ Thanks
Old Mar 20, 2006 | 07:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm running one with Trickflow heads. Will be running it on Dart Pro1 200cc heads. It can be run on stock heads. Regarding the Brodix heads see if they have the provision for EGR if you have to worry about smog. If they do not you would have to go to the Corvette style EGR setup.
Old Mar 21, 2006 | 09:40 PM
Dave Farr's Avatar
I'm using it with Vortec heads on my truck works well but expensive.
Old Mar 22, 2006 | 12:20 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
One version is for Corvette heads with the older bolt pattern, the other style is drilled for both newer and older bolt patterns. And the third version they have now is for Vortec heads.
Hotrodboba400
Dec 10, 2019 07:07 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
Stroopwafel
Sep 11, 2015 06:38 AM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
