replacment heads
Old Mar 21, 2006 | 08:27 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
replacment heads
I just bought a used set of heads for my 86 305tpi iroc and would like to know if this set will work for my car
the casting is 14014416 305 1.85 intake 1.5 exhaust
i planned on having them rebuilt and ported. the price really cheap so im just hopeing they will work.
Old Mar 22, 2006 | 07:06 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
If memory serve's me corectly thats the stock heads your 86 TPI car has on it right now, I know they came on the 86 LG4 and the 86 L69 305's forsure
Old Mar 22, 2006 | 08:14 AM
Vader's Avatar
Hawk is correct. They should work fine so long as they are not damaged.
The first thing to do is strip them down, have them cleaned and magged. If they are intact, open the intake bowls to 1.94", bowl-hog them to the top of the ports on both sides, move a 2" shell mill over to the chamber perimeter another .050-.060", scribe the gasket outines at the flanges, blend them in, then fit them to these templates:
That should provide about 177cc/64cc port volumes, and if the valves are set correctly, 57cc chamber volumes after unshrouding. That should provide a bit more peak flow, yet not so much that the TPI will lose effective velocity/charging in the preferred lower RPM ranges.
Old Mar 22, 2006 | 07:14 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
Right on, now I feel better. thought i bought these for nothing. now i dont have to worry, i can have these rebuilt and still drive the car for now.
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
BBSDesigns
Aug 11, 2015 07:39 PM
