can u block off EGR for tpi 350,s
Old Mar 23, 2006 | 04:36 PM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
looking to block off the egr valve on my 350 can it be done will the car run bad and is there a block off plate for it
plus i was told it would run fine cuz its more for the polution system
Old Mar 23, 2006 | 05:44 PM
MdFormula350's Avatar
I had to make a delete plate.
Not having the egr will make the ses come on from time to time, but my egr wasnt working after i did headers so i got the code 32 ses light anyway. so i just got rid of it and it runs as good as it did before. i plan to delete it from the computer some time down the road.
Old Mar 23, 2006 | 06:31 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
yeah, you can block it off. I blocked it off and never got a trouble code. TPIS make a block off plate..... Part #100-021 Billet EGR Valve block-off Plate,L98.......$12.00
www.TPIS.com
(952)448-6021
----- Eric
Old Mar 23, 2006 | 10:12 PM
mcwpns's Avatar
Car: 1989 firebird/91 tpi formula
Engine: 327 small block/305 tpi
Transmission: 700 R4
Axle/Gears: superior axles/3.42's
You can also have a chip programmed to delete certain pollution controls such as your egr....vats....and smog pump
Old Mar 24, 2006 | 07:38 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If u block it off.
U should also get it turned off in the prom.
It does add timing in cruise when its expecting the EGR to be on and some other small issues.
later
Jeremy
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
